- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
KeepAlive/ Connection Timeout - VPN Setup on IOS
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, I'm trying to setup a VPN from the built in capability in my Netgear modem/router (D7800), however I keep getting 'Connection Timeout' on the iPad.
The router has the latest firmware V1.0.1.10, iPad has IOS 10.0.2 and OpenVPN is 1.0.7 build 199.
I have tried changing many of the OpenVPN IOS settings but it makes no difference.
The latest OpenVPN log is copied below, grateful for any assistance.
Thanks, Russell
16-10-08 10:20:16 EVENT: RESOLVE
2016-10-08 10:20:16 Contacting xxxxxxxxx via UDP
2016-10-08 10:20:16 EVENT: WAIT
2016-10-08 10:20:16 SetTunnelSocket returned 1
2016-10-08 10:20:16 Connecting to [xxxxxxxxx]:22973 (xxxxxxxxxxx) via UDPv4
2016-10-08 10:20:16 EVENT: CONNECTING
2016-10-08 10:20:16 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,cipher AES-128-CBC,auth SHA1,keysize 128,key-method 2,tls-client
2016-10-08 10:20:16 Peer Info:
IV_GUI_VER=net.openvpn.connect.ios 1.0.7-199
IV_VER=3.0.11
IV_PLAT=ios
IV_NCP=2
IV_TCPNL=1
IV_PROTO=2
IV_LZO_STUB=1
IV_COMP_STUB=1
IV_COMP_STUBv2=1
2016-10-08 10:20:16 NET Internet:ReachableViaWWAN/WR t------
2016-10-08 10:20:16 NET WiFi:NotReachable/WR t------
2016-10-08 10:20:19 VERIFY OK: depth=0
cert. version : 3
serial number : 01
issuer name : C=TW, ST=TW, L=Taipei, O=netgear, OU=netgear, CN=netgear, ??=changeme, emailAddress=mail@netgear.com
subject name : C=TW, ST=TW, L=Taipei, O=netgear, OU=netgear, CN=netgear, ??=changeme, emailAddress=mail@netgear.com
issued on : 2016-03-15 01:30:34
expires on : 2036-03-10 01:30:34
signed using : RSA with MD5
RSA key size : 1024 bits
basic constraints : CA=false
cert. type : SSL Server
key usage : Digital Signature, Key Encipherment
ext key usage : TLS Web Server Authentication
2016-10-08 10:20:59 Session invalidated: KEEPALIVE_TIMEOUT
2016-10-08 10:20:59 Client terminated, restarting in 2...
2016-10-08 10:21:01 EVENT: RECONNECTING
2016-10-08 10:21:01 Contacting xxxxxxxxxxx:22973 via UDP
2016-10-08 10:21:01 EVENT: WAIT
2016-10-08 10:21:01 SetTunnelSocket returned 1
2016-10-08 10:21:01 Connecting to [xxxxxxxxxxxxxxx]:22973 (xxxxxxxxxx) via UDPv4
2016-10-08 10:21:01 EVENT: CONNECTING
2016-10-08 10:21:01 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,cipher AES-128-CBC,auth SHA1,keysize 128,key-method 2,tls-client
2016-10-08 10:21:01 Peer Info:
IV_VER=3.0.11
IV_PLAT=ios
IV_NCP=2
IV_TCPNL=1
IV_PROTO=2
IV_LZO_STUB=1
IV_COMP_STUB=1
IV_COMP_STUBv2=1
2016-10-08 10:21:11 VERIFY OK: depth=0
cert. version : 3
serial number : 01
2016-10-08 10:21:16 EVENT: CONNECTION_TIMEOUT [ERR]
2016-10-08 10:21:16 EVENT: DISCONNECTED
2016-10-08 10:21:16 Raw stats on disconnect:
BYTES_IN : 6584
BYTES_OUT : 30976
PACKETS_IN : 62
PACKETS_OUT : 104
KEEPALIVE_TIMEOUT : 1
CONNECTION_TIMEOUT : 1
N_RECONNECT : 1
2016-10-08 10:21:16 Performance stats on disconnect:
CPU usage (microseconds): 112024
Network bytes per CPU second: 335285
Tunnel bytes per CPU second: 0
2016-10-08 10:21:16 EVENT: DISCONNECT_PENDING
2016-10-08 10:21:16 ----- OpenVPN Stop -----
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: KeepAlive/ Connection Timeout - VPN Setup on IOS
Hello russellg
You may want to contact openvpn support to help with the config.
DarrenM
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
