- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
LB1110 4G Modem connection to Router D7800
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi All,
I have a D7800 on VDSL connection at the moment, but I would like to swap this connection from VDSL input to my new 4G LB1110 Modem instead.
What is the best way to change this?
Cat6 Cable from LB1110 into the D7800 (red internet port)
What settings would I require to change on the D7800 or LB1110 ?
Thanks
David
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: LB1110 4G Modem connection to Router D7800
You are planning to use the D7800 as a router?
There is a manual for the D7800 somewhere at the end of this link:
>>> D7800 | Product | Support | NETGEAR <<<
See the section Set Up the Modem Router for Cable or Fiber Service.
You can also use it as an access point, see Set Up the Modem Router as a WiFi Access Point Only.
