- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NETGEAR D6000 (Possible Firmware Bug) V1.0.0.68_1.0.1
- Mark as New
- Bookmark
- Subscribe
- Permalink
Recenty updated to V1.0.0.68_1.0.1.
I use it as a router. Everything works fine but can not use Lan setup-->Address Reservation.
I can see the devices in Address Reservation Table, i can select them but when click on ADD= a grey page appears.
How to add static ips?
How to get back to older firmware?
(another strange thing that tried is genie app cant connect too even in windows or android but dont care)
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for nice explanation of terms. I see that u can flash back... So i will give tomorrow another try with separate download if zip file
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NETGEAR D6000 (Possible Firmware Bug) V1.0.0.68_1.0.1
> [...] I can see the devices in Address Reservation Table, i can select
Sounds like bad firmware.
https://community.netgear.com/t5/x/x/m-p/1509146
"Reserved", not "static". A static address is configured on the
device itself. A reserved address is a dynamic address, supplied by a
DHCP server (in the router).
Visit http://netgear.com/support , put in your model number, and look
for Downloads. Under Firmware and Software Downloads, look for "View
Previous Versions. Find the kit(s). Download the kit you want. Read
the "Release Notes" file for instructions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
> Didn't got 1.0.0.68 in zip. Should i reflash with zip file?
You can try it, but I'd expect 1.0.0.68 to be 1.0.0.68, no matter how
it got installed.
> Or is a firmware bug?
I looks that way to me. Someone should try a settings reset, to see
if that changes anything.
