Orbi WiFi 7 RBE973
Reply
Nighthawk D7800 no wifi
Toffeehome
I am trying to configure a Nighthawk D7800 router in AP mode to act as a wifi extender.
i followed the instructions on
https/kb.netgear.com/24104/How-do-I-change-my-Nighthawk-router-to-AP-mode-after-I-ve-already-run-set...
and set it up with a fixed IP address.
All seems normal on the router (DSL light flashing, wifi and spa lights are on. ssid broadcast is set on both 2.7 and 5.
However I do not see either wifi signals on a pc or iPad.
I have tried changing channels and resetting both router and Nighthawk and updated firmware to latest v1.0.1.56
Any ideas?
Message 1 of 4
Re: Nighthawk D7800 no wifi
Those are the instructions for a router. The D7800 is a modem/router.
Have you read the manual for the D7800?
If you visit the support pages:
Support | NETGEAR
you can feed in the model number and find all the documentation for your hardware.
See the section Set Up the Modem Router as a WiFi Access Point Only.
Message 2 of 4
Toffeehome
I have tried to set this up multiple times using the instructions in the manual. I have also check out the online help.
Each time, it registers on my network via a wired connection, but there is still NO wifi signal.
Starting to think this unit is a waste of money!
Would like to hear from someone in Netgear about this problem.
Model: D7800|Nighthawk X4S – AC2600 WiFi VDSL/ADSL Modem Router
Message 3 of 4
antinode
Guru
> Nighthawk D7800 [...]
   Firmware version?
> [...] and set it up with a fixed IP address.
   Which "a fixed IP address", how, exactly?  And connected what,
exactly, to what, exactly?  (Hint: If a device has different types of
Ethernet ports, then "connected to device" is not enough detail.)
> [...] router [...]
   What, exactly, is your "router"?  Which IP subnet does its LAN use?
> [...] All seems normal on the router (DSL light flashing, [...]
   "seems"?  Define "normal"?  "DSL light flashing" is normal?  Is the
DSL port connected to anything?
   LED indicators?  (And "normal" is not a useful description.)
   What does the management web site on the D7800-as-WAP have to say for
itself?
   Does the "WiFi On/Off button with WiFi LED" have any effect?
   Firmware defects in Netgear products are not uncommon.  Have you
tried a different/older version?
   When it's configured as a router, is there a signal?  Does it work if
you connect a wired device to a LAN Ethernet port on the D7800-as-WAP?
   Visit: http://support.netgear.com/
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1261 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
