Orbi WiFi 7 RBE973
Reply
R7000 DHCP Reservation
thenashy
I'm trying to reserve a single IP address on a D7000, and the only information states that I can't do this with DHCP enabled.  Surely this isn't correct?
How do I do it?
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 6
Re: R7000 DHCP Reservation
There is support material, including a manual, for the R7000 somewhere at the end of this link:
>>>> R7000 | Product | Support | NETGEAR <<<<
See page 125. Reserve LAN IP Addresses
Your footer says D7000. That is here:
>>> D7000 | Product | Support | NETGEAR <<<
See page 209.
Message 2 of 6
antinode
Guru
> I'm trying to reserve a single IP address on a D7000, [...]
   Please decide what your model number is, D7000, R7000, or whatever,
and also report the firmware version.
> [...] and the only information states that [...]
   What "information"?  Manual?  Error message?
   You "can't do" _what_, exactly?  "I can't" is not a useful problem
description.  It does not say what you did.  It does not say what
happened when you did it.  As usual, showing actual actions with their
actual results (error messages, ...) can be more helpful than vague
descriptions or interpretations.
   Perhaps not, but that might depend on exactly what you did, and
exactly what happened when you did it.  Address reservation is possible
_only_ with DHCP enabled; it's a DHCP feature.
> How do I do it?
   What, exactly, would you like to do?  (Why?)
Message 3 of 6
thenashy
In my router settings I do not see LAN Setup.
Without this option, I don't see a way to reserve an IP.
Message 4 of 6
antinode
Guru
   Still wondering.
   It should be under ADVANCED (tab) > Setup > LAN Setup :
Address Reservation
   It should be there.  (Unless you're running some non-Netgear
firmware.)
Message 5 of 6
We still don't know what your hardware is. R7000 or D7000?
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2888 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
