- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WNR 2000v5 - Unable to create LAN Connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
i have problems with my ethernet connection. I rolled my Router back to factory settings. Wi-Fi is working fine, but i can't connect any device with LAN. I've set my router as a AP. It's connected to my modem. I don't use static IP Adresses etc. If i connect for example my PS4, or Android TV via cable, it's impossibel to get a connection. Any advice?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WNR 2000v5 - Unable to create LAN Connection
If you are connecting to a real modem - not a router / modem combo, then you will never get an Ip address, and never get out to the internet. You should confingure the AP as a router, if you are connected to a true modem.
http://www.downloads.netgear.com/files/GDC/WNR2000V5/WNR2000v5_IG_19June2014.pdf
- Mark as New
- Bookmark
- Subscribe
- Permalink
But why had it worked before? I haven't changed anything.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Whats the model number of the ISP modem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's a Fritz Box Fon 5050 (Germany)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
All of them are on.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I wouild suggest once again, resetting the Negear to factory default, and re-configure frmo scratch..
