mehulwarade
Dec 21, 2021Aspirant
Getting individual port POE values using SNMP
Hi,
I am trying to get command line access using SNMP to my switch to get the individual POE values like the wattage and current.
I can see that we can turn on and off individual ports in this discussion:
The switch says that it support POWER-ETHERNET-MIB which should allow me access to monitor the POE values. Can someone please help me find the exact oid that will get me the values for individual ports.
I have attached my snmpwalk output in the discussion.
Does this still apply with the recently released firmware 6.0.10.5?
https://www.netgear.com/support/product/GS728TPv2.aspx#download
PS: Requesting a moderator to move this thread to the appropriate Smart Plus And Smart Pro Managed Switches Forum section
- mehulwaradeAspirant
Thanks for the replies.
schumaku wrote:Does this still apply with the recently released firmware 6.0.10.5?
The link you provided is for the model GS728TPv2. My model is GS724TPv2 and the latest firmware on the download page is 2.0.7.4. That firmware is not working.
Do you reckon I can use the 6.0.10.5 firmware of GS728TPv2 on my GS724TPv2?
https://www.netgear.com/support/product/GS724TPv2.aspx#download
Sorry, my mistake. Ignore that other device model firmware.
The POWER-ETHERNET-MIB (easier to read as decrypted than the MIB file here http://www.circitor.fr/Mibs/Html/P/POWER-ETHERNET-MIB.php) does various PoE aspects. For example, you find the nominal and measured power for the PoE subsystem, the PoE classes by port - but not actual power usage (Watts or Amps) by port as you are looking for.
Netgear has implemented NETGEAR-POWER-ETHERNET-MIB http://www.circitor.fr/Mibs/Html/N/NETGEAR-POWER-ETHERNET-MIB.php, the NETGEAR Power Ethernet Extensions MIB containing this or the similar information - in my understanding this is not available on this class of switches.
