Orbi WiFi 7 RBE973
Reply
Re: RBK853 - Only about 8 Entries in the Router Logs
vfromdc
Guide
My log in the router only shows about 8 last entries. How do I get see more entries there?
Also I coudn't get Email working because gmail rejects it from logging into my email accont. Any ideas how to make it work?
Message 1 of 62
Guru
What browser are you using?
Message 2 of 62
vfromdc
Guide
Firmaware: V3.2.15.25_1.3.15
At the momemnt Edge, Firefox and Chrome all are showing 7 entries in the RBK853 router logs.
Message 3 of 62
Guru
Entries similar to mine?
[Admin login] from source 192.168.0.101, Tuesday, May 05,2020 15:59:22
[Admin login] from source 192.168.0.101, Tuesday, May 05,2020 15:49:46
[Admin login] from source 192.168.0.101, Tuesday, May 05,2020 15:44:19
[Admin login] from source 192.168.0.135, Tuesday, May 05,2020 15:08:02
[Admin login] from source 192.168.0.135, Tuesday, May 05,2020 15:07:27
[Internet connected] IP address: 192.168.0.85, Monday, May 04,2020 10:21:48
[Initialized, firmware version: V3.2.15.25_1.3.15] Monday, May 04,2020 10:21:48
Mines in AP mode though...not sure if there should be more entries or not...
Seems to be max limitation here as I log in from different PCs:
[Admin login] from source 192.168.0.100, Tuesday, May 05,2020 16:25:20
[Admin login] from source 192.168.0.109, Tuesday, May 05,2020 16:23:42
Message 4 of 62
vfromdc
Guide
Yes pretty much. Right now it is showing:
[Admin login] from source 192.168.1.25, Sunday, May 24,2020 15:13:35
[DHCP IP: (192.168.1.16)] to MAC address 00:11:D9:5E:C9:59, Sunday, May 24,2020 15:13:29
[DHCP IP: (192.168.1.16)] to MAC address 00:11:D9:5E:C9:59, Sunday, May 24,2020 15:12:49
[DHCP IP: (192.168.1.29)] to MAC address 00:11:D9:61:32:91, Sunday, May 24,2020 15:12:35
[DHCP IP: (192.168.1.16)] to MAC address 00:11:D9:5E:C9:59, Sunday, May 24,2020 15:12:26
[DHCP IP: (192.168.1.24)] to MAC address F0:78:07:1B:2C:B7, Sunday, May 24,2020 15:11:17
[DHCP IP: (192.168.1.16)] to MAC address 00:11:D9:5E:C9:59, Sunday, May 24,2020 15:11:07
Message 5 of 62
vfromdc
Guide
Have no idea how the smileys got in there, they are not in the logs. Please ignore them.
Message 6 of 62
Chuck_M
Mentor
Silly question:
Do you have the "Include in Log:" boxes checked on ADVANCED -> ADMINISTRATION -> LOGS?
What boxes are checked there?
Message 7 of 62
vfromdc
Guide
Yes, all 'include in' boxes are checked:
Include in Log
Attempted access to allowed sites
Attempted access to blocked sites and services
Connections to the Web-based interface of this Router
Router operation (startup, get time etc)
Known DoS attacks and Port Scans
Port Forwarding / Port Triggering
Wireless access
VPN Service
Message 8 of 62
Chuck_M
Mentor
This may be a candidate for a factory reset.
Message 9 of 62
vfromdc
Guide
Do I reset just the router or the router and the satellites?
Also, I will have to do this when my wife is not using the system, she works from home.
Message 10 of 62
Guru
I reset mine yesterday and see only see these few enteries. Just reset the RBR.
When copy and pasting, remove the MAC address value from the paste before posting to the forum.
Message 11 of 62
vfromdc
Guide
OK, thanks FURRYe38.
But your router also shows only 7 entries. As you said, that may be the limit, which is strange. Typically I have seen hundreds of entries (I mostly used ASUS routers in the past). Not sure resetting will do anything if 7 is the limit.
Message 12 of 62
Guru
I don't either. Maybe something NG should look into.
@Blanca_O
@Christian_R
Message 13 of 62
Chuck_M
Mentor
I would just do the Router.
As long as you dont have a complicated setup, it is a piece of cake and takes a lot less time that you would imagine.
I would read up on the steps to perform just to be very clear.
Message 14 of 62
Blanca_O
NETGEAR Moderator
Hi @vfromdc @FURRYe38 @Chuck_M
Let me check on this. I will get back to you for any updates.
Blanca
Community Team
Message 15 of 62
Guru
Thank you.
Message 16 of 62
KMDonlon
Luminary
I can confirm a max of 7 log entries, all entries we're logged with no maximum on previous firmwares
Message 17 of 62
Guru
Thanks for letting us know others are seeing this. Hopefully NG will review this soon.
Message 18 of 62
KMDonlon
Luminary
Log entries started to work properly again, getting more than 7 again.... Not sure what changed
Message 19 of 62
Guru
Interesting. And no FW updates. Smiley Frustrated
Message 20 of 62
KMDonlon
Luminary
Very interesting.... puzzling for sure
Message 21 of 62
Guru
Seeing more in the logs awell since putting my Orbi AX back online yesterday in router mode. Smiley Wink
Message 22 of 62
KMDonlon
Luminary
I have never had mine in AP mode ever, only router mode... Super weirdness going on
Message 23 of 62
Guru
Ya, mines been mostly AP Mode.
Wondering if something they can fix in the cloud services that the Orbi is tied too. Smiley Frustrated
Message 24 of 62
vfromdc
Guide
Nothing changed for me, I still have 7 entries as before.
Message 25 of 62
Top Contributors
Discussion stats
  • 61 replies
  • 4205 views
  • 7 kudos
  • 7 in conversation
Announcements
Orbi WiFi 7
