Reply
2.4 ghz suport
Csmken
2.4 ghz suport
i bought a new cabals modem router and now my 2.4 ghz device does not work. Doesn’t this modem router suport 2.4 ghz.  Thanks
Message 1 of 5
schumaku
Guru
Re: 2.4 ghz suport
Cable Router Modem - exact model please?
Message 2 of 5
Csmken
Re: 2.4 ghz suport
Model c3700v2
Message 3 of 5
schumaku
Guru
Re: 2.4 ghz suport
As per the C3700v2 Data Sheet it does support both 2.4 GHz and 5 GHz WiFi.
  • IEEE® 802.11 b/g/n 2.4GHz
  • IEEE® 802.11 a/n 5GHz (Note: The C3000v2 does not support 5 GHz)
On the device, there are LED for both bands - check that the 2.4 GHz is not off:
C3700v2 LED:
2.4 GHz radio
  • Green. The 2.4 GHz radio is on.
  • Blinking green. There is activity on the 2.4 GHz WiFi band.
  • Off. The 2.4 GHz radio is off.
5 GHz radio
  • Green. The 5 GHz radio is on.
  • Blinking green. There is activity on the 5 GHz WiFi band.
  • Off. The 5 GHz radio is off.
Message 4 of 5
Csmken
Re: 2.4 ghz suport
  1.  thanks
Message 5 of 5
Discussion stats
  • 4 replies
  • 454 views
  • 0 kudos
  • 2 in conversation
Announcements
