Reply
C3700 can not find networks 2.4 and 5.0 lights are not on. can find no addresses to join.
joecapper
Luminary
Model: C3700|N600 Cable Gateway Docsis 3.0
Message 1 of 4
antinode
Guru
Re: C3700 can not find networks 2.4 and 5.0 lights are not on. can find no addresses to join.
   Is that accurate?  Not C3700v2?  Look at the product label.
   Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation.  Get the User Manual.  Read.  Look for the
LED descriptions and "Troubleshoot".  Pay particular attention to the
"WiFi On/Off button with LED".  Did you press it?  (Further reading
might be helpful, too.)
Message 2 of 4
joecapper
Luminary
thank you for your quick response. have looked at the manual, depressed the 2 second button on the back of the router. still, radios do not turn on. comcast suggests that bridge mode should be off. netgearl recommends against this.
Message 3 of 4
antinode
Guru
   Still a mystery.
> [...] depressed the 2 second button on the back of the router. [...]
   What, exactly, does "the 2 second button on the back of the router"
mean to you?  What does the User Manual call your "the 2 second button
on the back of the router"?  As I read the C3700 User Manual, the "WiFi
On/Off button with LED" is on the "Front Panel" of the router.
> [...] comcast suggests that bridge mode should be off. [...]
   Bridge (modem-only) mode would disable all the router functions of
the C3700, including its wireless-network radios.
> [...] netgearl recommends against this.
   Huh?  "against" what?  Where, exactly, does Netgear recommend what,
exactly?
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 410 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
