Reply
Can you connect USB-printer to WNDRMAC?
lithium1330
I just purchased this router today and getting it setup to replace my Zxyel. I'm seeing conflicting information between the website & box vs. the product documentation about connecting a USB printer to this route.
So, on the website and the box, it says I can do a ReadyShare Printer. However, the documentation says I should not connect a USB printer to the USB port. Am I missing something?
Message 1 of 5
jmizoguchi
Virtuoso
Re: Can you connect USB-printer to WNDRMAC?
USB HD only,,,,,,,,,
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 5
lithium1330
Thanks!
I was able to get Bonjour working on the MBP, but not on my Win7 (x64). It seems I can see the printers in Bonjour after reboot... but when I try to print from an application (browser, word, etc...) it crashes. Bonjour freezes up and does nothing. Or, if I launch the Bonjour wizard from start menu, the Windows circle spins for a few seconds, then nothing. Anyone else seeing this?
Message 3 of 5
jmizoguchi
Virtuoso
opes.. WNDNRMAC is both USB HD and printer.. my bad.
http://support.netgear.com/app/answers/detail/a_id/19136
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 4 of 5
aryouwhy
You may want to try instructions from http://support.apple.com/kb/DL999. Make sure to uninstall previous Bonjour programs installed on your Windows PC, and also note the firewall requirements.
Message 5 of 5
Discussion stats
  • 4 replies
  • 3837 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
