Reply
Cannot connect to Genie through wireless on WNDR3400v2
DrStang
Luminary
Hi,
I just bought the WNDR3400 v2 and set it up, to include installing the new firmware. I've also installed the Genie app.
The only problem I've been having is that I am unable to connect to either 192.168.1.1 or 192.168.0.1 (getting the "problem loading page" error on Firefox) or the Genie app (getting a Login Failed! Please check to see that this computer is connected to the NETGEAR router error) on my wireless applications (laptops or phones). I can connect the Genie app and the 192... webpage no problem on my desktop plugged directly into the router.
I've googled this, and have tried all the suggestions I found for people with similar problems, however I haven't been able to find the exact problem. I've also disabled my firewalls, without any luck.
This wouldn't be that big of a deal, however I can't connect to ReadyShare either on my laptop, which I would really like to take advantage of.
Any help will be greatly appreciated! TIA!
Message 1 of 3
jmizoguchi
Virtuoso
Re: Cannot connect to Genie through wireless on WNDR3400v2
Hard reset the route since you already flash new firmware
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 3
DrStang
Luminary
Great, thanks! I thought I had hard reset it trying to fix it, but I guess I didn't do it right...
Thanks again.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3513 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
