Reply
DGN1000 and Second Life
amigadevil
I have been supplied with a DGN1000 from Orange but when I try to connect to Second Life on the internet, I am being signed out aprox every 2 minutes.
Does anybody know of a solution to this? thanks
Message 1 of 8
jmizoguchi
Virtuoso
Re: DGN1000 and Second Life
change idle timeout to "0" under basic settings of the router interface
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 8
amigadevil
idle timeout is on 0, I believe other people have had this problem and have solved it, but I cannot find a solution anywhere on the internet
Message 3 of 8
Atsura
same for me , i can't do sim crossing or tp in second life or i am disconected.
No prob with orange router "livebox 2"
I am just bored and give up ... my last netgear product
Message 4 of 8
ruffrecords
I have exactly the same problem with Cube (Sauerbraten).
I have tried adding its UDP ports both in and outbound to the firewall rules but it makes no difference; just get a network disconnect (normal) message after a minute.
No problem with my previous router.
Cheers
Ian
Message 5 of 8
vale
hi! i hope you soled the problem in the meanwhile. I hv a netgear DNG1000 with orange too and had massive problems staying connected for more than2min. then i found this post (in italian)http://www.secondlifeitalia.com/community/viewtopic.php?f=4&t=27240#p260217 which suggests to use PPPoA/LLC instead of PPPoA/VC. problem solved!!!
Message 6 of 8
gudda
Thank you for your tips.
My internet connection does not require a login, so I cannot change the idle timeout. If I try using a login my internet does not work.
My router was already set to PPPoA/LLC. If I try with PPPoA/VC it does not work.
Any more ideas?
Message 7 of 8
giddy
Hi folks
I am new to forums, and indeed new to netgear. I bought a netgear N150 and when I log second life it boots me off in a couple of mins. I have been told its to do with firewall and ports. I am a pooter halfwit and need help.
I was given this link but i don't have any clue how to follow it.
http://wiki.secondlife.com/wiki/Configuring_your_firewall
any help I would be grateful :-)
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 4259 views
  • 0 kudos
  • 7 in conversation
Announcements
