Reply
DGN1000 port 80 forwarding fix
Retired_Member
Not applicable
Don't know if this will help anyone but we support a lot of customers with the DGN1000 router, some of them require port 80 open for OWA, small websites, etc.
We have found that having remote management enabled disables your ability to forward port 80...even if you change the remote management port!
Just as a heads up to anyone in case it helps Smiley Happy
Toby
Message 1 of 4
jmizoguchi
Virtuoso
Re: DGN1000 port 80 forwarding fix
you can report issues to support at my.netgear.com
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 4
plazy
Just a follow on to this, anyone know how to enable fowarding of 443?
Seems that its use by the router too and I cant seem to assign it to an IP behind the router either.
Message 3 of 4
jmizoguchi
Virtuoso
some router has preconfigured with basic ports. did you check the service ports with https before you create your own 443 ports?
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3033 views
  • 0 kudos
  • 3 in conversation
Announcements
