Reply
FM114P WAN Port limited to 10 Mb/s
Wildwood1
Follower
Hi
I have a FM114 which has been running perfectly on my Virgin Media (UK) Internet 10 Mb/s service. It was upgraded to the latest firmware some time ago.
A couple of days ago my network was upgraded to the Virgin Media 30 Mb/s service but testing shows that my download through the FM114P is limited to 10 Mb/s.
The font panel shows both the Internet 100 and LINK/ACT lights lit.
I have connected a PC directly to the Virgin Media Modem using the same cable as is plugged into the FM114P WAN port - testing confirms that 30 Mb/s is being provided by the modem.
It's almost as if the WAN port is a 10 Mb/s rather than a 10/100 Mb/s one.
I can't see any configuration options that could affect this so I'm apealing to the Forum for any ideas.
Message 1 of 3
Computer_User1
Re: FM114P WAN Port limited to 10 Mb/s
This is an old router and it's a normal limitation of the WAN to LAN throughput. I used to have a FR114P, the wire only version of your router, it can only go 7 Mbps at best.
Message 2 of 3
jmizoguchi
Virtuoso
wrong place to post
http://forum1.netgear.com/showthread.php?t=15136
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2935 views
  • 0 kudos
  • 3 in conversation
Announcements
