Reply
Help tracking down why my WIRED connection is SLOW
jlewter
Guide
Re: Help tracking down why my WIRED connection is SLOW
ipconfig /all
sometimes the brain doesnt spark.....
Message 26 of 31
fxtech
Did the netsh thing and rebooted. Still slow.
Windows IP Configuration
Host Name . . . . . . . . . . . . : andor
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : NVIDIA nForce Networking Controller
Physical Address. . . . . . . . . : 00-1B-FC-8D-00-B7
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::f574:c6a9:8099:e5f2%11(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.6(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Monday, October 25, 2010 11:24:40 AM
Lease Expires . . . . . . . . . . : Tuesday, October 26, 2010 12:35:38 PM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 234888188
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-12-AF-61-07-00-1B-FC-8D-00-B7
DNS Servers . . . . . . . . . . . : 216.146.35.35
216.146.36.36
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter isatap.{5036ADD9-9C65-4774-B805-247B68A13ED0}:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 9:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
IPv6 Address. . . . . . . . . . . : 2001:0:4137:9e76:149e:fee:3f57:fef9(Preferred)
Link-local IPv6 Address . . . . . : fe80::149e:fee:3f57:fef9%13(Preferred)
Default Gateway . . . . . . . . . : ::
NetBIOS over Tcpip. . . . . . . . : Disabled
Message 27 of 31
ccdoggy
for what its worth I had to get a new intel nic to get connected again to my router. worked great for a few months then refused to connect gigabit. I could set it to 100 meg and it would work for a while but never ever gig. No idea what happened. tried dozens of drivers, old and new, cables galore (cat5, 5e, 6) still nothing. Bought a intel NIC and its worked perfect ever since. Mine would connect but get truly terrible speeds and any time i tried to transfer a file it would start the transfer and then just die a half a second later basically rendering the connection dead. It was an onboard nvidia gigabit ethernet. I dont think it has to do with any IP settings, routing, or such things. my money is on a hardware issue. data flows so its not a route issue.
Message 28 of 31
jlewter
Guide
I wanted to see routings to make sure the gateway and adapters were properly set...
If the op is moving the ethernet cable from 3700(lan) to modem and finds that his connection is a-okay then that makes ya want to lean away from a hardware fault..
The only other thing I might suggest would be to disable IPv6 and QoS and SEE if it makes a difference... My guess is no...
In windows7, click on your connection icon, go into network and sharing center, click change adapter settings, find the lan, right click propertys, and then remove IPv6 and QoS... I wouldnt do them at the same time... IPv6 first then test... Then both off...
could you provide a ipconfig /all when your connected to modem (no need to see your net ip) .. I doubt it will be of any use, but never know..
I mean, okay, I might buy it as a hardware fault, bad ethernet cable.. Perhaps the modem has more umph and the line is cleaner... *shrug*...
at a loss..
Message 29 of 31
NatRay
Tutor
fxtech wrote:
There are several of these:
[DHCP IP: 192.168.1.6] to MAC address 00:1b:fc:8d:00:b7, Monday, October 25,2010 06:12:39
For that IP address, looks like there is one every 10-15 minutes or so. Normal?
I would like to take a closer look at the noted DHCP issue. requesting a lease every ten or so minuets is NOT normal. On a real DHCP server, an Administrator can control the lease period. This can't be done on the WNDR3700. Its DHCP server is hard wired for twenty two hour leases. This is an indication that a Link Connection is lost forcing the client to request an IP.
An IP conflict, miss-matched MAC (if associated with a DHCP reservation), or hardware failure can cause repeated lease request . . .
    Best regards,
    Nat Ray MCSE/MCT since 1997
    _______________________
    Cox Communications > SB6120 DOCSIS 3.0 > WNDR3700v1 (4), WNDR3400v2 (2), WPN824v2 (2), R7000, RT-N66R *AP(s) via Wired Backbone* > Ooma Telo / D-Link DGS-1024D > NeoTV-550 (3) . . .** HPEnvy800 -PHX **
    DD-WRT v24-SP2 (12/14/11) std. Build 18007
    Optimize your network: Disable IPv6 . . . Post responsibly . . .
    ‘Quality trumps Quantity’
    Message 30 of 31
    wevie
    So this issue was never resolved? I am have the exact same problem.
    Message 31 of 31
    Top Contributors
    Discussion stats
    • 30 replies
    • 13604 views
    • 0 kudos
    • 7 in conversation
    Announcements
