× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
[LB2120] How to enter MCC and MNC for APN configuration?
Azerty32
Initiate
Hello,
I have a LB2120 4G router and I have some difficulties to configure the APN - usage in France. My mobile provider is a MVNO called Symamobile. I am supposed to enter a MCC and MNC to configure the APN. This is what I did on my mobile phone and it works. However, I see no possibility to enter MCC MNC on LB2120 APN settings page. Only APN=symamobile.com is not sufficient. The power led remains orange and the home page of LB2120 says that 3G/4G is disconnected, that I should enter an APN.
Is there any workaround or should I conclude that it will be impossible to configure it?
Thank you in advance for your help!
Model: LB2120|4G LTE Modem
Message 1 of 3
Re: [LB2120] How to enter MCC and MNC for APN configuration?
@Azerty32 wrote:
Hello,
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your LB2120 hardware. That's probably here:
Mobile Routers, Hotspots & Modems
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Message 2 of 3
Azerty32
Initiate
@michaelkenward wrote:
@Azerty32 wrote:
Hello,
Support | NETGEAR
Hello,
Thank you for the tips.
I already checked the manual and could not find the solution. I hope someone could help me otherwise I will choose another device (or mobile provider).
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1201 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
