Reply
My WNDR3400v3 loses up to 65 percent of signal strength
themover1
Follower
My WNDR3400v3 with the latest firmware loses from 60 to 65 per cent of my cable signal,  I have wired directly to the modem and get 60 dpms
using my router I get from 18 to 24, and sometimes lower. I am running 2 windows laptops, an iphone and an ipad{never all at the same time},
and the output is not good.  Is this common for this router, and is there a fix or do I just need to get a better router?
Message 1 of 2
TheEther
Guru
Re: My WNDR3400v3 loses up to 65 percent of signal strength
You haven't told us how your router is configured, especially the wireless settings.  Have you tried changing Wi-Fi channels?  Is Internet Access QoS enabled?  Is WMM enabled?  Are you using WPA2 security?
Do you have anything that could disrupt the Wi-Fi signal?  Cordless phones, baby monitors, thick walls?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2150 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
