Threather's avatar
Threather
Netgear WND4300 Inconsistent pings
Model: WNDR4300
Firmware: v1.0.2.88
OS: Windows 10
I am currently running into an issue where if I connect my PC to my WNDR4300 via ethernet cable or wireless, I have major ping issues.  I am currnetly running versions 1.0.2.88 firmware on the router.  I have confirmed this is not an issue with my PC as I am able to directly connect to my cable modem and I get flawless pings.
Below are my test results of pinging straight from my PC to the IP address of the router.  The environment I used to test this was the router plugged directly into a power outlet (to rule out surge protector causing power problems), PC hard wired into the router (results do not differ when WiFi), and a ping to the IP address of the router itself.
Reply from 192.168.1.1: bytes=32 time=295ms TTL=64
Reply from 192.168.1.1: bytes=32 time=1ms TTL=64
Reply from 192.168.1.1: bytes=32 time=595ms TTL=64
Reply from 192.168.1.1: bytes=32 time=892ms TTL=64
Reply from 192.168.1.1: bytes=32 time=1190ms TTL=64
Reply from 192.168.1.1: bytes=32 time=296ms TTL=64
Reply from 192.168.1.1: bytes=32 time=593ms TTL=64
Reply from 192.168.1.1: bytes=32 time=889ms TTL=64
Reply from 192.168.1.1: bytes=32 time=1187ms TTL=64
Ping statistics for 192.168.1.1:
    Packets: Sent = 253, Received = 253, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 1ms, Maximum = 1294ms, Average = 330ms
  • Welcome to the community, Threather
    What are the devices connected to your network?
    Try to connect one by one and then do a ping test.
    This is to verify if there's a device that's causing this.
    Have you tried reinstalling the firmware? How about factory resetting the unit?
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    • Threather's avatar
      Threather
      My apologies for the late reply, i've been constantly troubleshooting the issue and having to let it run for 3-4 days before i could confirm if it worked or not.
         Only my Laptop was connected to the router, the router was not even connected to the cable modem
         This occurred from multiple devices when solo connected to the router
         I updated to the latest firmware, and then I re-flashed the firmware to no avail
         After 7-days of testing, this has fixed the issue.
