Reply
Security Options Can't be Changed
ScratchFive
Follower
I'm having trouble changing the security options for my wireless network. I need to use WPA-PSK [TKIP] + WPA2-PSK [AES] (especially for the 2.4ghz band) but every time I select this option and click on Apply, it defaults back to just WPA2+PSK [AES]. Any suggestions? Am I missing something here?
Message 1 of 2
covillen1
Apprentice
Re: Security Options Can't be Changed
hey ScratchFive,
I was having the same problem. Here is what I did to fix it.
Change to security option to " none " on the frequency you want and click apply. After this is done it will most likely kick you off the WI-FI. just log back in and go back and change the security option to what you need. Hopefully this works for you. Come back and post and let me know if it worked for you or not. I bet you anything someone else is having the same problem too. 🙂
Message 2 of 2
Discussion stats
  • 1 reply
  • 8031 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
