Reply
Sudden change in iPhone signal strength
iceman027
Running my WNDR3700 fine for over a year with no problems connecting to my home wifi network on my wife and mines iphone.
Suddenly we can only connect our iphones to the wifi network if we are standing right next to the router. My ipad, other two laptops, and apple tv have no change in connection and have a strong signal.
I have updated the routers firmware to the latest version, tried channels 1,6, and 11 and still have the problem. I've restored our iphones as well and still nothing.
Is there anything else I can try to remedy this problem?
Message 1 of 8
jmizoguchi
Virtuoso
Re: Sudden change in iPhone signal strength
understand correctly..
iPhone -OK
iPad- NO
Laptops (2) -NO
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 8
iceman027
iPhone -OK
iPad- NO
Laptops (2) -NO
No, it's the other way around, everything connects fine to the network except our two iphones. They only connect if you physically standing right next to the router.
Message 3 of 8
jmizoguchi
Virtuoso
assume you tested other hotspot wifi location and has not issues right?
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 4 of 8
iceman027
Yes, the phones connect to other wifi hotspots with no issues.
Message 5 of 8
isnogud
maybe your appleTV and laptops connect via 5GHz?
then your 2.4GHz radio is broken ...
Message 6 of 8
ccampy
u assume you tried different wi-fi channels and modes as somebody else maay have changed there settings
Message 7 of 8
jmizoguchi
Virtuoso
do you have unique SSID name instead of default SSID names? it does sounds like 2.4Ghz side could be faulty unless other devices are connected on 2.4Ghz as well
you should able to know but looking at SSID name you choose on apple tv and other products
make sure BOTH band of SSID is different so you know which one you are connecting
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 8 of 8
Discussion stats
  • 7 replies
  • 2209 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
