Reply
WNDR4500 will not support 6TB USB drive?
mootpoint
I'm trying to upgrade from an older USB 2.0 3TB Western Digital hard drive to a USB 3.0 6TB Western Digital hard drive connected to the router's USB port.
I realize the Router supports speeds up to USB 2.0, but I assume a 3.0 drive will still work, albeit at slower speeds.
I had never gotten the ReadyShareConnect application to work reliably. A year ago, I started connecting by mapping the drive via IP address, instead.
I disconnected the old link in Windows Explorer. The old IP address no longer appears as a drive in Windows Explorer.
The router does not appear to be interfacing with the new drive. The drive works when connected directly to my Windows 7 computer.
I get a canned message when trying to map the new drive: Check the spelling or there is a network issue.
Could it be that USB drives will not work unless the ReadyShareConnect application is installed?
Model: WNDR4500|N900 Wireless Dual Band Gigabit Router|EOL
Message 1 of 8
Guru
Re: WNDR4500 will not support 6TB USB drive?
I've struggled to get most usb drives >4tb to work with readyshare. Some do work, others not even close. And the WNDR4500 is a significantly older device. Here's the confirmed compatible drives list.  its not all inclusive but I don't see much on here with larger capacities.
https://kb.netgear.com/000060825/Will-my-USB-drive-work-with-ReadySHARE-Old-Models
Current Setup: CM2000-> SXK30-> GS716v2-> RAXE500->
Message 2 of 8
mootpoint
If it is the case that larger drives do not work with the WNDR4500, is it also the case they will not work with the newest routers, either? Do I need to look at another brand?
Message 3 of 8
Guru
You can check the list.
https://kb.netgear.com/18985/Will-my-USB-drive-work-with-ReadySHARE
I know I've had an 8TB working on my RAX200. I think it was/is a seagate. I might have shucked it for a NAS so can't remember off the top of my head.
Message 4 of 8
mootpoint
The WNDR4500 will not connect to the 6TB Western Digital Elements (WDWLG0060-0B).
Why? How is one drive that different than another? This must be related to the router firmware, which hasn't been updated in many years. I could look into third-party firmware, but I'm not feeling that ambitious right now.
I have some 636 GB remaining, so this is not a pressing emergency. I will buy a new router in the coming weeks, something I've clearly been putting off.
I wish USB hard drive support were more robust.
Message 5 of 8
Guru
Its also something you can check into with the format.
https://kb.netgear.com/24059/What-are-the-USB-drive-requirements-for-my-Nighthawk-router
Issue with many external drives is when they need drivers. If they need a driver installed, they usually won't work.
Message 6 of 8
mootpoint
Over the years, I've bought a lot of external hard drives, between one and two dozen. I've never bought one that needed drivers to operate. Didn't even know that was a thing.
I'd like to know why these routers will work with so very few specific models. I know XP won't recognize drives larger than 2TB, due to a limitation in its ability to access memory. If I buy a new Netgear router, will I be facing the same problem, that it will recognize but a small handful of specific makes and models?
Message 7 of 8
Guru
The reason they work with specific models is that during testing, if the alpha/beta testers have that modem and it works, its put on the "works" list. Thats why it isn't an all inclusive list. I do know the older models had issues past 4gb.
My RAX works with an 8TB seagate drive that I ended up shucking.
Many external hard drives need drivers which is why you see a lot of "usb device not recognized" or "external drive not showing up" in seagate/western digital forums. Its usually incorporated into windows but its harder with routers as there's more limited storage versus a windows install.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 665 views
  • 0 kudos
  • 2 in conversation
Announcements
