Habibulalam's avatar
Jun 10, 2016
Wireless distribution system
netgear R6220 ac1200 router are support Wireless distribution system(WDS) or not, if it support WDS, how to set-up
My New router is netgear R6220 ac1200 and old router is Tenda F303, so how to set wireless bridge between them.
  • Thanks for your great respose. May i get details WAN Medium. Also how to disable the firewall/NAT functions on the Tenda. I want to just connect both router "Netgear R6220" and "Tenda F303" without any wire by how any how. i'll be grateful to you if you will help to me by instructing to connect both router.
    Thanks again.
  • Retired_Member's avatar
    Retired_Member
    What does the Manual say?
  • I want to connect Tenda F303 with Netgear R6220 wirlessly. how to connect them without wire?
    • TheEther's avatar
      TheEther
      Guru
      I'm pretty sure the R6220 does not support WDS.  Even if it did, you wouldn't want to use it because WDS support on Netgear routers is very poor.
      It looks like you can set the WAN Medium Type to wireless on the Tenda.  This will allow you to connect to the R6220's Wi-Fi network.  The only downside is that the Tenda will behave as a router, not as a bridge.  Unless you can disable the firewall/NAT functions on the Tenda, devices connected to the R6220 won't be able to communicate with devices connected to the Tenda.
      • Habibulalam's avatar
        Habibulalam
        Tutor
        Thanks again.
  • I suggest that you look online for the Tenda manual. Alternatively, just look around on the router. It shouldn't take you too long to find the appropriate settings.
