Reply
dgn2200, connection ok but broswer can't access web
zorz
Follower
hi all!
I've a strange problem with my new dgn2200 router...when I use for about 20 or more hours a p2p program (emule or torrent), sometimes I can't access web sites but the p2p program continues to download/upload normally, so it isn't like a normal connection problem...
to resolve the problem I have to reboot my pc and router, else I have problem with internet broswing
I never had this problem with my old netgear, a dg834GT
could it be a sort firmware bug?
if it can help, my windows 7 64bit pc is connected with lan cable to the router, no antivirus or antimalaware programs noticed my any infection and i use the connection settings for emule and torrent like I used in the "old" dg834gt, with a small number of maximum connection and a poor max upload...my internet provider is the italian telecom
Message 1 of 2
jmizoguchi
Virtuoso
Re: dgn2200, connection ok but broswer can't access web
generally speaking for torrent usage, you need to use lower than 100 concurrent connection. if older DG worked probably should work the same as older unit sure to work less concurrent connection but try lower less than 100 and see on torrent app settings
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 2
Discussion stats
  • 1 reply
  • 2588 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
