somesuga's avatar
somesuga
jnr1010v2 is not connecting to the internet but working fine when i connect cable directly
Hello,
I have a 1 year old netgear wifi router, model number JNR1010v2. It was working fine until recently. It does not connect to the internet since a week .I suspect that it is because of the firmware upate to VersionV1.1.0.32_1.0.1. Since then i am facing the difficulties in connecting. I have showed the problem to my Service provider and he said the MAC id is the problem and he removed the MAC id for my connection. But after a week of the fix i am facing the same problem.
However, I am able to connect to the inetenet if i connect the ethernet cable directly to my laptop or PC. If i connect the same ethernet cable to the router, all the 3 led lights(Power, Internet n wifi signals)for the internet does light up & i am unable to connect to internet,
Can you please suggest a solution to my problem?
Details:
Model Number: JNR1010v2
ISP: Excell Media  (Provides an ethernet cable to home).
Service provider provides staic IP,subnetmask,default gateway etc
Thanks in advance
Ganesh
  • Hello somesuga
    Welcome to the community!
    After the firmware update, did you reset the router?
    If not, I suggest that you do a factory reset by using a paperclip to push the reset button on it for 10 seconds.
    Once done, reconfigure the router. Follow the steps here on how configure
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    Hello somesuga
    • somesuga's avatar
      somesuga
      Thanks ElaineMfor your quick response
      I have tried resetting the router after the firmware update. It didn't work.
      This time i tried again and it was not able to connect,  i have given the Router MAC id to configure the Internet and it did worked.
      Thanks again..
      GAnesh
      • ElaineM's avatar
        ElaineM
        You're very welcome.
        Glad that it's working now.
        Have a great day!
