Reply
netgear wndr3700v3 questions
AlienInside
Novice
is there anyway to select which pc can access which folder on a usb hard drive like each pc has only the access to the folder I wish to select because I can only find allow all access read/write or admin only read/write .
thank you
Message 1 of 7
Scubbie
Apprentice
Re: netgear wndr3700v3 questions
To the best of my knowledge the WNDR3700 only allows for one username/password.
I would suggest that a dedicated NAS drive would be a better choice in this instance.
With the Netgear ReadyShare NAS drives you can configure specific folders to be available to difference groups or individuals. As each person would have to use the log in ID & password, the NAS knows who is accessing the folders.
Since you can have multiple groups associated with each folder or perhaps multiple individuals, there is far better scope for doing what I suspect you are asking.
You can also specify, for example, that every can 'read' say the media folder, but only specified people have read/write access, thus protecting your movie & music collection.
Message 2 of 7
AlienInside
Novice
okay I guess I will get a network drive.
Thank you
Message 3 of 7
jmizoguchi
Virtuoso
look for ReadyNAS units.
http://www.netgear.com/business/products/storage/readyNAS-profam/default.aspx
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 4 of 7
AlienInside
Novice
also should i enable ap mode i have two wired pc's a laptop and a playstation vita
thank you again
Message 5 of 7
Scubbie
Apprentice
Specifically what do you mean? AP tends to mean 'Access Point' and relates to a WiFi Access Point specifically.
If the WiFi is enabled then you should be able to use it.
Message 6 of 7
AlienInside
Novice
I am sorry I didn't know what ap mode was but i do now and i don't need to use it.
thanks for helping me.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 3448 views
  • 0 kudos
  • 3 in conversation
Announcements
