Reply
Highlighted
usb router access
firmware updates do not work
any readyshare access does not work
any readycloud access does not work
it is insane to suggest dropping SMB 1.0 security settings so you people can slither your Wannacry Ransomware into everybodies systems????
all suggested changes to make file explorers show these folders do not work
this has been 2 days of combing thru every suggested solution
the solution is to use the router only for smartphone wifi and avoid every single other feature netgear seems to think it can offer you
avoid them like the plague and just move your stuff around with bluetooth, a usb or just tether your phone to your pc....
the rest of the netgear efforts are waaaaaaay too scary, here...
Message 1 of 2
Highlighted
Re: usb router access
Re: Readyshare not working Windows 10. - NETGEAR Communities
Hard to advise without know what the router is or what firmware it is running.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
Discussion stats
  • 1 reply
  • 193 views
  • 0 kudos
  • 2 in conversation
Announcements
