Reply
wired port very slow on wpn824n
schroeder71
a blu-ray player is the only thing wired to my wireless router and im only getting about 500kbps for speed. wired it straight to the modem and i get 10mbps for speed. wireless speed seems fast enough, i dont know how to test the wireless speed. network is secured and the only other device on the network is a galaxy tablet. cant stream movies without quality issues or interruption. please help, thanks.
Message 1 of 3
jmizoguchi
Virtuoso
Re: wired port very slow on wpn824n
you need to check with PC wired to the router and do the speed test
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 3
schroeder71
ok, from a laptop wired to my network with the same ethernet cable, i performed a speed test and it said the download speed was around 5mbps. so looks like the blu ray player is the problem? i dont understand, i just purchased this player because the old one was this slow as well. anyways, thank you for your help.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2291 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
