Reply
Follower
Can't login to routerlogin.net
Trying set up old wgr614v6 router on a Sony Vista laptop. Downloaded current setup.
I can't log in to routerlogin.net using admin, password or 1234. After 3 attempts I get 414 error.
I'm stuck.
Luminary
Re: Can't login to routerlogin.net
WRONG AREA
moving to Super-G (108 Mbps) & 802.11g (54 Mbps) Routers
hard reset the router..
see "router reset" see my sig.... step1
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Novice
my PC not work the disc how to login
Luminary
not sure what you mean
Follow prior suggestion and re setup your router
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Dear IVYMCD,
You don't need to use a disc to set up the router -- just connect it to the computer using ethernet cable (usually included in the box with router).
Read the quick start leaflet on how to address the router's user interface using your web browser (can also download reference manual via link at top of this page).
I have the excact same problem as 2oldman
i use admin and password like said but it doesn't work
i have resetted my router and i already established a username and password for the routerlogin.net page; i completed all of the steps to connect the router to my LT. all cables are connected and right now my LT is connected to the router and the router is connected to my cable modem. i am able to get online like this. what do i do now?... do i disconnect the ethernet or what??
Luminary
"i am able to get online like this. what do i do now?... do i disconnect the ethernet or what??"
what is your point
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
I put a wep code for my wireless internet and now I cannot log into my account. I have tried http://www.roterlogin.net but it keeps telling me that the address cannot be found. I cannot use the wireless internet anymore. Is there a nother way to login? Thank You
Luminary
use pc wired the router and login the router
reset the router as well check your wireless issues
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 9 replies
  • 51361 views
  • 0 kudos
  • 7 in conversation
Top Contributors
