Reply
WNR Aspirant
N750 Randomly drops connection
Others facing this issue?
Is there a beta version of a new firmware? Or is this some deeper issue that I should return this router to Netgear?
Was this also an issue on the 3700? This may influence my decision to keep the router or not...
Thanks
Re: N750 Randomly drops connection
Thanks
it sounds like you have the 1.0.0.66 firmware, check and make sure, if you do go here and download the original 1.0.0.60 firmware and install it, the newer firmware has disconnect issues.
Discussion Stats
  • 1 reply
  • 3833 views
  • 0 kudos
  • 2 in conversation
Top Contributors
