Reply
Recovery of Network Password
N600, WNDR3400. Installed router, wrote password down on sheet of paper..wife threw out in trash! How do I recover:confused: Need PW to get into my Kindle Fire for a book download. Some guidance would be appreciatedSmiley Happy
Retired_Member
Re: Recovery of Network Password
If you lost you router PW then a factory reset( push reset button until power led blinks) to default settings (admin password) will allow you to setup and enter a new router password and enter all your configs. If you know router password log into router under wireless settings to find wireless passphrase. as for kindle fire I have no idea what you're trying to do. contact kindle
Tutor
That's kind of drastic for a lost password.
JK Smiley Very Happy
Like searay said, you're gonna have to do a reset on the router and re-enter any changes you made from the default. Unless you previously made a backup of the router's configuration. In which case, after you reset the router, log in with the default credentials and load the configuration file to restore settings.
_____
WNDR3700v1 (v1.0.7.98NA) - Router uptime (d:h:m:s): 1155:02:31:46 - How To Check and Change Your Router's Firmware: http://forum1.netgear.com/showthread.php?t=63234
Luminary
I think OP means trash the password notes not the router
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
searay, I really feel like a dum dum on this so bear with me. Is the admin password you speak of my computer admin password. If so, I don't have one. I'm a single user and never set up a separate admin password. In layman's terms, what do I specifically do after I press the reset button? Why couldn't I simply delete the router from my computer and reinstall from scratch?:confused:
Disregard. I found the password. It's on the package. I was thinking I had established a password. Not so.....it is plainly stated on the box the router came in. So, if the question ever arises again. Push the reset button is not the answer.... look on the box would be the first suggestion!
Luminary
It's also in router manual
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Tutor
Have you ever logged into the router's configuration? If you have, then you are aware that the router requires a Username and Password. I'd post a link to the user manual, but you haven't provided the WNDR3400 revision number.
The default Username is "admin" and the default Password is "password" (both without quotes). This only works if, one, you never changed the default credentials (not good). Or two, have reset the router.
If you have changed the default password and have not reset the router, then log into the router with "admin" (without quotes) and whatever Password you chose when you changed the default Password. If you don't have the Password, then you will have to reset the router. See above paragraph for defaults.
The Passphrase' has to do with wireless access and is not a Password (at least as far as Netgear products are concerned). Presuming that you are not using the wireless from the router without security, when asked you would provide the security Passphrase when your wireless device attempts to connect to the router's radio.
So, when you say, "Need PW to get into my Kindle Fire for a book download" it reads like you lost the password to the Kindle. In the off chance this is not what you meant, then it sounds like you lost the Password to the router and not the Passphrase for wireless.
So, now that you know these terms have different meanings, what is it that you actually need?
_____
Retired_Member
Had you read the manual and followed the guidelines you would had changed the password and would had no other option but to use the reset button.
Your initial post stated your wife tossed out the piece of paper with password written on it. Based on that statement a reasonable person would assume you changed it.
So if the wife tosses out the box someday look on the bottom of the router seeing how you probably still haven't changed the password you can find there.
Luminary
User already figure out it so this close thread
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Tutor
Unfortunately, their response wasn't available at the time of posting.
Regardless, keeping the default log-in password should not be encouraged. The default password is NOT secure and should be changed at the first opportunity.
_____
Discussion Stats
  • 10 replies
  • 5937 views
  • 0 kudos
  • 4 in conversation
Top Contributors
