Reply
Follower
pin number on router
When working online to try to connect my new Kindle to this router it asks for
an 8 digit pin which says is on the router, but it isnt where do I find this when I no longer have the paperwork that came with the router?
Apprentice
Re: pin number on router
No1Twin wrote:
...8 digit pin which says is on the router, but it isnt where do I find this when I no longer have the paperwork...
Quick answers:
- look on the label affixed to the bottom of the router.
- Search in the GUI - you should find it.
I'm not familiar with how the Kindle connects to your wireless network, but doesn't it scan and present you with a list of networks it sees? Doesn't it give you a choice of which network you wish to connect to?
What I'm driving at is it's much better to be able to select your network and enter your passphrase when requested, or to manually create a network profile to connect to in your Kindle. I believe if you use the WPS (Wifi Protected Setup) method to connect your Kindle to your network, it changes your passphrase to a random one which the WPS process selects. If I'm right and your network's passphrase is changed then it means you would have to input the new passphrase in all your client devices that were using the old passphrase. Do you really want to go through that?
Luminary
Wrong..
WPS uses PIN to connect and by using WPS between the route rand devices continually change the security to keep the system hack is what WPS is made rather normal passphrase uses same pass phrases which can be hack in long run 'If" some continue to try for weeks and weeks to hack typical wireless.
WPS itself has own exploitation issues but concept of key changing suppose to be more effective.
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
How do you search the GUI
NETGEAR Moderator
@3Nacaos3 Are you looking for the WPS Pin? What's the model number of your NETGEAR device?
ElaineM
Community Team
How to connect netgear router to my laptop..?
NETGEAR Moderator
@joshnats How will the laptop connect to the router? Wired or wireless?
What's the exact model number of the NETGEAR router?
Troubleshooting wireless networks
ElaineM
Community Team
Master
First use capital letters for PIN. pin is typically used for refering to pins on connectors. Look at guest network set up section under
wireless set up.
Discussion Stats
  • 7 replies
  • 41517 views
  • 1 kudo
  • 7 in conversation
Top Contributors
