Reply
wndr3400 & wndr3400 v2 wireless repeat function
Hello,
I am trying to setup a wireless router in my garage using the wireless repeat function.
WNDR3400v1 is already attached my network and working properly with the wireless signal.
I have a WNDR3400v2 I would like to setup using the wireless repeat function.
On the WNDR34000v1:
Enabled 2.4GHz - Checked
Wireless Base Station - Radial Circle Selected
Disable Wireless Client Association : Checked
Repeater MAC Addresses added : Address 1 and Address 2
On the WNDR3400v2:
Wireless Repeater - Radial Circle Selected
Base Station IP Address: added
Base Station MAC Addresses added : Address 1 and Address 2
After I enabled these functions on the WNDR3400v2 - I am no longer able to access the router, like it becomes unresponsive. I have tried to power off for a few mins and then power back on, but I end up having to reset factory settings to get back into the setup pages of the router.
Is there any suggestions for why this would be happening or maybe I am missing something on setting this up. Thank you
Tutor
Re: wndr3400 & wndr3400 v2 wireless repeat function
You can visit my post on this thread below:
http://forum1.netgear.com/showthread.php?t=76149
It's almost the same process unless if the GUI is Genie.
Luminary
for security reason you will be limited to WEP/54Mbps or no encryption. WEP is 100% hackable
return the unit and get extender -wn2500rpt,wn2000rpt.
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
thanks for the reply.
Yes, it is the Genie version, but the main issue is that the v2 unit does not seem to be responsive after I enable repeater mode.
I am aware of the WEP issue but not concerned about it. thank you thou
Luminary
make sure both has different IP
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Tutor
YEs, you won't be able to access the gui after applying the settings. That's because you provided a different IP address for the 3400v2 to use when enabling the Wireless Repeating Function of it. When you access the gui, it's no longer 192.168.1.1. Do you remember the Repeater IP Address that you created for the WNDR3400v2???...That's the IP address that you should type on the browser to access the gui.
Discussion Stats
  • 6 replies
  • 11447 views
  • 0 kudos
  • 3 in conversation
Top Contributors
