Orbi WiFi 7 RBE973
Reply
Genie won't login after firmware update
Mishipishi
Re: Genie won't login after firmware update
Bob,
How can we get this latest update (V1.0.1.46_1.0.32) that you mentioned?
My system says 1.0.1.22 is latest version for R6100
Message 26 of 30
Bobrud
Tutor
R6300
Message 27 of 30
Bobrud
Tutor
I don’t know if the firmware versions are different for different products. I haven’t looked at the online help to see if updating firmware is covered; if not, try the network support folks. A messsage popped up on my genie telling me I had to update and then took me right to it.
Message 28 of 30
Mishipishi
Netgear, are you monitoring this forum? Your iOS genie app doesn’t work with R6100! It’s been many months since this was brought up on this forum by so many.
Any updates?
Model: Genie|Desktop| Mobile| and Product Setup Genie
Message 29 of 30
Lomara
I see the original poster has marked this thread solved.
I have a WNDR4300 which has yet to receive any firmware update. (It is still on V1.0.2.104, and no new version appears when checking for an update)
I see the Genie iOS app has received several updates. I'm on the latest one, version 3.1.74
I was able to use it successfully to login to my WNDR4300, and can control and see my attached network devices. I haven't encountered any issues with it yet. It appears to work as intended. My problem appears to have been solved.
Message 30 of 30
Discussion stats
  • 29 replies
  • 18067 views
  • 13 kudos
  • 13 in conversation
Announcements
Orbi 770 Series
