- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
No longer have access Drop down menus in Genie
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all,
I have an old WNR3500Lv2 and updated the Genie software to V1.2.0.54
In the Genie menu I used to be ble to access from a dropdown menu's pages to configure the router.
Now there are no dropdown menus's and cannot access for example manual setting for IP etc.
Is this a change and normal?
Maybe someone can explain a reason, or help?
Tony
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Itstony wrote:
I checked downloads and could not even see the version V1.2.0.54?
It is still there.
WNR3500Lv2 | N300 WiFi Router | NETGEAR Support
View Previous Versions
Try the newer version. The release notes explain how to install it:
WNR3500Lv2 Firmware Version 1.2.0.56 | Answer | NETGEAR Support
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: No longer have access Drop down menus in Genie
Sorrry I should have tried harder to find the forum. Even that is not well thought out either.
Anyway, loads written on this, poor show from such an established company from the comments.
So is it possible to revert to an older version? I just cannot see this being that easy if it had of been an option. It would have been recommended long ago.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is still there.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
Thank you for the assistance. It's been ages since I used this netgear and thanks to your help I now recall how to access through .net login
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
