Orbi WiFi 7 RBE973
Reply
Router failing to display devices
rbrown3
I believe I have found a bug in the software for this router.
   I am logging into the Netgear Genie software and go to the Basic home page. In the "Attached Devices" section, I see 27 devices connected (with the computers, phone, and tablets, that is about right).
   I then click on the "Attached Devices" button.  The display shows only 2 devices.
   The display shows the two devices in alphabegtical order.  If I click on "sort by Connection Type", I sometimes see 4 devices.  Most often I see nothing.
   Something is clearly wrong with this software. Is there a way to fix this problem, or is there somewhere I can report this bug?
   Someone please advice.
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 2
Re: Router failing to display devices
The desktop genie for Windows gives a better count of attached devices.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2287 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
