frankflores's avatar
frankflores
netgear genie
I can not get to netgear genie by using run command and the router IP.
I can use the browsers Chrome and Edge to get to it.
In the past I was able to use the run window short cut to get to the router page and it was very handy. How can I get it to work again.
   Frank
  • michaelkenward's avatar
    michaelkenward
    You refer to the genie. This could be one of several things, the browser interface, a Windows or Mac program for a PC, or a mobile Android/iThing app. Netgear labels them all as genies. Which are you using?
    What are you trying to achieve?
    • frankflores's avatar
      frankflores
      I have posted a JPEG of the one I have.
      Not sure which one it is.
      I want to be able to use the RUN window to get to it like I used to do.
      It was a short cut where I would open the run window and select the IP for the router.
