rogerp
Oct 07, 2018Aspirant
Enabling Weighted Load Balancing Dual WAN, incoming forwarding breaks
We have a working SRX5308 with a single WAN (WAN1) and incoming port forwarding working for several services (HTTP, SMTP, etc.)
When I connect a second WAN (WAN2), and then enable Weighted Load Balancing, incoming port forwarded traffic via WAN1 to the destination servers no longer works.
For example. we have port forwarding on WAN1 to a web server. We enable load balancing including WAN2, we can no longer connect to that server from the outside.
Any ideas why enabling load balancing would seem to break incoming port forwarded traffic on WAN1?
- DaneANETGEAR Employee Retired
- rogerpAspirant
Protocol Binding is used to bind *outgoing* traffic to a particular WAN interface. My problem has to do with incoming traffic.
Unless what you're suggesting is that (eg. HTTP) traffic coming in on WAN1, is port forwarded to a particular server, and a protocol bind is necessary to guarantee that server's responding outgoing HTTP traffic heads back out through the same WAN. But shouldn't traffic normally always return on the WAN interface it comes in on?
Kindly double check the inbound firewall rule/s configured in order to ensure that the incoming service is still sent to the correct LAN server. If ever the inbound rule/s is still set correctly, then configure protocol binding as a test to see if it works.
DaneA
NETGEAR Community Team
