kkwan
Oct 10, 2018Follower
FVS318G or FVS318Gv2?
Have a FVS318G ProSafe Gigabit 8-Port VPN Firewall. No packaging or manual. Is there any way to determine which hardware version, FVS318G-100NAS or FVS318G-200NAS? Possibly by serial number?
Hi kkwan,
Welcome to our community! :)
You may try to compare the firmware version of your device to our support site. As per the firmware version, FVS318Gv2 has the initial release of v4.3.1-9 and for the last firmware of the FVS318G is v3.1.1-18.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
1 Reply
- JohnC_VNETGEAR Employee Retired
Hi kkwan,
