jrswartz's avatar
jrswartz
Follower
Aug 04, 2017
FVS336GV3 power adapter
How can I get a replacement power adapter for a FVS336G V3 VPN Firewall?   What are the specs if I need to find one outside of Netgear?
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi jrswartz,
    You just need to create a chat / case online on NETGEAR support in order to provide you the replacement power adapter if ever the device is still under warranty. Power adapter: 12V DC, 1.2A.
    Here is the datasheet for reference. Welcome to the community!
  • JohnC_V's avatar
    JohnC_V
    jrswartz,
    I would like to have a follow up on this thread. Please let us know if you still need further assistance and just in case that the reply would be the answer to your issue. I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
ProSupport for Business
