Orbi WiFi 7 RBE973
Reply
VPN Client Lite license key reset.
RoebuckComms
Hi Team,
We have been experimenting with the VPN client for our hardware and due to a technical error had to reimage the machine, we are now unable to re-activate the VPN Client Lite software as the license is still activated. Please could you help reset the license.
Thanks in advance,
Martin.
Model: FVS318Gv2|ProSafe gigabit 8 port VPN firewall
Message 1 of 4
Accepted Solutions
JohnC_V
NETGEAR Moderator
Re: VPN Client Lite license key reset.
@RoebuckComms,
We already reset the license key that you provided. May you be able to try installing the key?
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
JohnCarloV
NETGEAR Community Team
Message 3 of 4
All Replies
JohnC_V
NETGEAR Moderator
Hi RoebuckComms,
Welcome to our community! 🙂
Please send me the license key via pm together with the e-mail address that is used to activate it.
JohnCarloV
Message 2 of 4
JohnC_V
NETGEAR Moderator
@RoebuckComms,
JohnCarloV
Message 3 of 4
RoebuckComms
Sorry for the late reply, Thank you for your help the software has been reregistered.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2017 views
  • 0 kudos
  • 2 in conversation
Announcements
