brianjmurrell
Feb 02, 2023Tutor
Can't reach GUI on GS308E over VLAN trunk port
I have a simple network with two VLANs, 1 and 15. VLAN 1 is the general LAN. Most ports on my switches are in VLAN 1, untagged as that's the VLAN most devices talk to each other on.
So I configured my GS308E to have the two VLANs, 1 and 15 set port 1 to tag both VLANs and all other ports to be in VLAN 1 untagged.
Devices from anywhere on my network on (untagged) VLAN 1 ports can reach devices on the GS308E's untagged VLAN 1 ports. So all in all, VLANs and tagging/trunking are working.
The problem comes when I try to reach the GS308E's web UI from a VLAN 1 port anywhere on the network except the GS308E. It cannot be reached. It can be reached when physically connected to the GS308E.
Now, if I unplug the trunk cable, and instead plug one of the untagged VLAN 1 ports of the GS308E into an untagged VLAN 1 port on another switch, I can access the GS308E's web UI from anywhere else in the network, even on machines not connected to the GS308E's untagged VLAN 1 ports, but connected to some other switch in the network.
It feels very much like the web UI is not bound to VLAN 1 on the GS308E, but I wonder then why it can be accessed from ports on the GS308E that are assigned to VLAN 1, or can be accessed from VLAN 1 ports on other switches but only if the "uplink" to the GS308E is untagged.
The simple controller design is not workable over tagged trunks.
Ugh! Really!?!?
So deploy one of these switches anywhere in an existing network a never again reach it without walking over to it with laptop?
Well, I suspect it won't even get an IP from a DHCP server over a tagged trunk also, right? So definitely no reaching it.
Is this common? Do other brands (tp-link, etc.) of similar switches have the same limitation?
Correct.
All the product lines built around the same chipset series, implemented and offered by various brands, are affected.
Switch designs build on real fully blown managed cores. Keep your eyes open.
