wanderson's avatar
wanderson
Follower
May 06, 2016
Cant forward both Unicast and Multicast traffic to a port. RIP, IGMP, PIM
I have the IP option installed in my XSM7224S.  I am trying to create a single router testbed where I forward/route both unicast and multicast traffic.  My multicast receiver support IGMPv2.
Since I am a standalone device I have no PIM or RIP routing neighbors.  When I enable unicast (RIP) routing, the forwarding of multicast frames ceases. ( before I enable RIP it was  forwarding frames).
One fundamental question I have is, is there any reason that this can not be done on a XSM7224S.  On my cisco I have to enable PIM to get this to work. I've tried but that didn't make any difference. On the XSM if I enable PIM I cant get mcast to forward, period, even without RIP configed.  It's unclear how to configure a RP and BSR in this case.
 My config is shown below. A host on interface 1/0/13 sends both ucast and mcast UDP packets to a host on interface 1/0/14.  Unicast traffic flows but no multicast traffic flows.  I see both the IGMPv2 membership queries from the XSM to my mcast receiver and the join response.
 I know this is a lot to ask but any guidance is appreciated.
Thanks for your time
Bill Anderson
(XSM7224S) #show running-config
!Current Configuration:
!System Description "XSM7224S - 24-Port 10G SFP+ Layer 2 Stackable Managed Switch with four 10G combo ports"
!System Software Version "9.0.1.42"
!System Up Time "0 days 0 hrs 59 mins 15 secs"
!Additional Packages FASTPATH QOS,FASTPATH Multicast,FASTPATH IPv6,FASTPATH Stacking
!Current SNTP Synchronized Time: Not Synchronized
enable password 3ff0630a15d65167b35d06d45dd7c111bb59346427fec531babbf3bc284950ccefffa49481b8c8be5536071b4e6faa1358754f345181fdc01fa2cd170ea82733 encrypted
network protocol none
network parms 192.168.100.71 255.255.255.0 192.168.100.1
vlan database
set igmp 1
set igmp querier 1
exit
configure
sntp client mode unicast
stack
member 1 1
exit
slot 1/0 3
set slot power 1/0
no set slot disable 1/0
ipv6 router ospf
exit
ip routing
username admin password 3ff0630a15d65167b35d06d45dd7c111bb59346427fec531babbf3bc284950ccefffa49481b8c8be5536071b4e6faa1358754f345181fdc01fa2cd170ea82733 level 15 encrypted
aaa authentication enable "enableList" enable
line console
exit
line telnet
exit
line ssh
exit
spanning-tree configuration name "00-8E-F2-59-68-24"
snmp-server sysname "labnetgear"
snmp-server location "lab"
set igmp
set igmp unknown-multicast filter
set igmp querier
set igmp querier address 10.10.10.1
ip igmp
ip multicast
interface 1/0/9
no auto-negotiate
ip address 192.168.110.1 255.255.255.0
exit
interface 1/0/10
no auto-negotiate
ip address 192.168.120.1 255.255.255.0
exit
interface 1/0/13
routing
ip address 192.168.50.1 255.255.255.0
ip rip
no ip proxy-arp
ip igmp
ip igmp version 2
ip igmp query-interval 60
exit
interface 1/0/14
routing
ip address 192.168.60.1 255.255.255.0
ip rip
no ip proxy-arp
ip igmp
ip igmp version 2
exit
router rip
redistribute connected
exit
router ospf
exit
exit
terminal length 0
No RepliesBe the first to reply
ProSupport for Business
