ColinRowland's avatar
ColinRowland
GS105 Switch not working with Sky Q Router
Hi
Bet you get a ton of these, anyway . . .
I'm not a techie, let me delcare that first, but want to learn.
I have Sky Q throughout the house and a Sky Q Router. It seems crazy to me that it only has x2 ethernet ports in the back so I bought a GS105.
Ive used one of the ports from the Router into the switch, then from the switch used two ports, one for Time Machine and one for Sonos. Problem is I cant connect to either. The Router continues to work fine ( internet Access ).
Do I have a compatibility issue, cabling issue ?
The instructions from the GS105 seemed pretty much plug and play.
Appreicate any help from you knowledgable folk.
Cheers.
  • schumaku's avatar
    schumaku
    There are two LED on each GS105 port (the older GS105 had - different from the GS105v5 - some additional indicators) - there is always a link LED and an activity LED. When connecting the switch to the router, the TimeCapsule, the Sonos - are the link LEDs active with the cables plugged?
    Don't know if the router has any Link and activity LED for each port - it's not uncommon the makers "saved" the money there however.
    The Sonos can cause some issues if currently using wireless and wired network - this can lead to a loop in the network, depending how "smart" the switches (or the switch in the router), and  a post might be shutdown for this very reason.
    • ColinRowland's avatar
      ColinRowland
      Thanks
      Looking at the very brief sheet that comes with the switch, the lights above the ports now indicate speed
      2 lights on = 1Gbs
      left light on - 100Mbps
      right light on 10mbs
      On the Sonos and Time Machine port both lights flicker in unison. On the Router port only the left light is on.
      It could be a cable issue, but Im completely guessing now. But will buy 3 new cables to elimnate it.
      Cheers for help.
ProSupport for Business
