- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
GS108PE Web access refused
- Mark as New
- Bookmark
- Subscribe
- Permalink
Dear NETGEAR suppport,
The following malfunction occurs on five PoE switches(GS-108PEv3) which I purchased recently.
* When I accecced by browser, connection is refused.
* But, This PoE Switch reply ping.
This PoE switch get IP address from DHCP Server.
It is poor hardware, or is this specifications change of the software?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: GS108PE Web access refused
As an image is not displayed, I attach it.
The error meesage is "ERR_CONNECTION_REFUSED".
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's not Netgear support here, we're just a community here.
Have no similar device to test. So just a little bit brainstorming:
Are these really GS108PEv3? Asking because other models of this product line come with an Access Control table, while the GS108Ev3, GS108PEv3, and GS308E do not support access control. Very early hardware models (GS108PEv1 if I remember right) factory firmware did not come with a Web UI.
Have done a factory reset using the Reset Button process?
What is the firmware in place? There is no need to login, the NETGEAR Switch Discovery Tool (NSDT) will show it.
If using a current v2.6.14 or so, there is a known limitation on this model series where connections with MTU different from the default 1500 (as over PPPoE, VPNs, and the like) don't allow establishing a connection.
What IP subnet is in use for these 10.255.x.x IP addresses?
As a test, can you try to connect the switches to a standard consumer router or the like serving e.g. the 192.168.0.x/24 or 192.168.1.x/24 subnet?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for your responce.
These PoE switchies are in remote site, I will try your suggestion later.
* Confirm model / Firmware version
* Factory reset using the Reset Button process
* NETGEAR Switch Discovery Tool (NSDT)
I will report it if I know a cause
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
hi,
i have the same switch as you.
when i use the nsdt tool , for accesing my switch, the tool says : cannot find any product.
my situation is :
isp modem in bridge modes, from this modem utp goes to netgear orbi system, ( left yellow port), from the port next to it agrregation ( also yellow) an utp goes to my switch.( most right port)
how can I enter my switch?
kind regards,
ernest.
