Nitish_Shah
Nov 17, 2023Aspirant
GS116Ev2 is throttling internet bandwidth
I have replace a 16 port Gigabit Ethernet Unmanaged Switch with GS116Ev2 16 port Gigabit Smart Managed Plus switch. My broadband bandwitch is 800mbits, I can test this bandwitch from the Hitron router, however the speed test from the rest of the network is around 400mbits.
The only configuration I have changed on the switch is to enable DHCP and added a IP address. for the switch, subnet mask and gateway IP.
I am not sure why the internet speed is reduced to less than 50% for devices connected to the switch.
Has anyone encountered the same issue? Is there some configuration that I need to change to get the full available bandwidth.
Appreciate some help.
Thank you
Any Rate Limitations in place and enabled on QOS -> Rate Limit ?
- Nitish_ShahAspirant
No, all the setting apart from DHCP are default values
