KBLUX2
Feb 28, 2018Aspirant
GS724TV4 SNTP Server - unable to add
| Product Name | GS724Tv4 ProSafe 24-port Gigabit Ethernet Smart Switch, 6.3.1.19, B1.0.0.4 |
Just updated to 6.3.1.19 firmware, as previous post suggested this as a fix, and rebooted.
Unable to set switch to use SNTP for time. This was using 'local' under firmware 6.3.1.11, and time/date was 1970...
Trying to add lu.pool.ntp.org as IPv4 or DNS gets the following error messages
Error! Failed to Set 'Port' with '123'
Error! Failed to Set 'Priority' with '1'
Error! Failed to Set 'Version' with '4'
Same errors if I use my gateway ip address.
1 Reply
- KBLUX2Aspirant
er, I guess I missed the "ADD" button - I was pressing "Apply" and getting the error message.
time-f.netgear.com and lu.pool.ntp.org as DNS entries in the SNTP servers list are not getting any response, but now my gateway address works via IPv4.
Case closed?
