ksb
Aug 18, 2017Aspirant
How to disable switch from sending LLDP multicast packets?
The M4300 switch keeps sending LLDP multicast packets every 15seconds even though LLDP has been disabled on all interfaces. Does anyone know how to stop those packets?
Thank you
- HopchenProdigy
Hi,
You have to disable the LLDP Transmit on the ports where you don't want LLDP packets to be send out of.
"System" --> "LLDP" --> "Port Configuration" --> Set "Transmit" to disable on the desired ports. Done.
Cheers
