- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
IBM PowerVM VIOS Load Balance, VLAN, Ethernet Link Aggregation, FAILOVER, Netgear M4300 12X12F
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello !!!!
Anyone with some experience?
We have 2 IBM VIOS with 4 ports each with speed 10 Gbits on all ports that we want to have with VIOS settings to use Load Balance and FAILOVER and VLAN and Ethernet Link Aggregation.
Customer complains on instablity and networks storms etc, but they have procured thier switches october 2018 and I need to use it.
In IBM VIOS we have:
$ lsdev -dev ent6 -attr
attribute value description user_settable
adapter_names ent2,ent3,ent4,ent5 EtherChannel Adapters True
alt_addr 0x000000000000 Alternate EtherChannel Address True
auto_recovery yes Enable automatic recovery after failover True
backup_adapter NONE Adapters to use when the primary channel fails True
hash_mode src_dst_port Determines how outgoing adapter is chosen True
interval long Determines interval value for IEEE 802.3ad mode True
mode 8023ad EtherChannel mode of operation True
netaddr 0 Address to ping True
noloss_failover yes Enable lossless failover after ping failure True
num_retries 3 Times to retry ping before failing True
retry_time 1 Wait time (in seconds) between pings True
use_alt_addr no Enable Alternate EtherChannel Address True
use_jumbo_frame no Enable Gigabit Ethernet Jumbo Frames True
- In Switch:
- Src/Dest IP and TCP/UDP Port fields
- Static mode = Disable (should then end up in Dynamic which is Netgear's designation of 802.3AD.
I now that LACP works fine with Cisco without any special VIOS settings, like VIOS settings above, that we now have tried.
Rgds Micael Eriksson
micael@wesolutions.se
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: IBM PowerVM VIOS Load Balance, VLAN, Ethernet Link Aggregation, FAILOVER, Netgear M4300 12X12F
Hello Micael,
Welcome to the Netgear Community!
@micael69 wrote:
- In Switch:
Should be very similar with any other industry standard switch.
When you look into the CLI of these switches, you find a very similar syntax as Cisco is using - where both Cisco and Netgear default to LACP for port-channels. What does "show port-channel all" show on the Netgear to start with?
(M4300-12X12F) #show port-channel all
Log. Channel Admin Mbr Device/ Port Port
Intf Name Min Link Mode Type Ports Timeout Speed Active
lag 1 WhateverLAG 1 Down En. Dyn. 1/0/1 actor/long 10G Full False
In case it's on static...
(M4300-12X12F) (Config)#port-channel load-balance 6 0/13/1
(M4300-12X12F) (Config)#interface 1/0/1-1/0/4
(M4300-12X12F) (Interface 1/0/1-1/0/4)#addport lag 1
1/0/1 interface is part of a port-channel.
1/0/2 interface is part of a port-channel.
1/0/3 interface is part of a port-channel.
1/0/4 interface is part of a port-channel.
(M4300-12X12F) (Interface 1/0/1-1/0/4)# port lacpmode
One point hitting my eyes (not relevant for now - more a performance thing) are the very different hash algorithms on the switch vs. the IBM VIOS side.
@LaurentMa you might want to join in here, please, too.
-Kurt
