- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
M4300-12X12F - LAG State Admin Mode D-Disable
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, I have 2 M4300-12X12F in stack.
After this error "Diagnostically disabling interface lag 8 as rate limit of 15 for 3 consecutive seconds has been exceeded"
I found both ports included in the LAG with admin mode disabled and the LAG State in D-Disabled mode.
I managed to re-enable Admin mode in switching -> ports -> admin mode but LAG State remains in D-Disable. In switching -> LAG i try to change LAG State in Admin Mode enabled but the change is not saved.
How can I reactivate the LAG without restarting the switch?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: M4300-12X12F - LAG State Admin Mode D-Disable
Hi, both ports number 3 of the netgear switch went into block were attached in lag towards an HP aruba switch, I am attaching a diagram of how the various switches are connected; the loop was probably generated by a switch3 reset procedure (HP).
thanks for the support
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I see both port 1/0/3 and 2/0/3 connect to switch2, and it will cause loop, Loop Protection will D-disable some port when detect loop. Is it necessary to connect two ports(1/0/3, 2/0/3) to switch2? Is it possible binding two ports as a lag?
And what about other port connection? such as lag1..lag8?
Could you please command as 'show spanning-tree summary' and 'show spanning-tree mst port summary 0 active', and print the output info here? I want to check which ports is discarding status.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, ports 3 were part of LAG1 it is correct that they are connected to switch2 to create redundancy in case of failure of one of the 2 netgear switches in stack. Right now they are disconnected I tried to remove them from the LAG to try to reactivate Admin Mode from D-Disable to Enable.
(M4300-12X12F) >show spanning-tree summary
Spanning Tree Admin Mode.......... Enabled
Spanning Tree Version............. IEEE 802.1w
BPDU Guard Mode................... Disabled
BPDU Filter Mode.................. Disabled
Configuration Name................ ****
Configuration Revision Level...... ****
Configuration Digest Key.......... ****
Configuration Format Selector..... 0
No MST instances to display.
(M4300-12X12F) >show spanning-tree mst port summary 0 active
STP STP Port
Interface Mode Type State Role Desc
1/0/15 Enabled Forwarding Designated
1/0/19 Enabled Forwarding Designated
1/0/23 Enabled Forwarding Designated
1/0/24 Enabled Forwarding Designated
2/0/4 Enabled Forwarding Designated
2/0/15 Enabled Forwarding Designated
2/0/19 Enabled Forwarding Designated
2/0/20 Enabled Forwarding Designated
2/0/23 Enabled Forwarding Designated
2/0/24 Enabled Forwarding Designated
lag 2 Enabled Forwarding Designated
lag 3 Enabled Forwarding Designated
lag 4 Enabled Forwarding Designated
lag 5 Enabled Forwarding Designated
lag 6 Enabled Forwarding Designated
lag 7 Enabled Forwarding Designated
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, got it.
I notice you diable STP mode on LAG1, right? It's mean LAG1 not participate spanning-tree caculate, and will casue broadcast stome. The root cause is 'BPDU Storm: An interface/port will go into D-Disable state if number of bpdus exceeds 15 for 3 consecutive seconds.'.
So please enable stp port mode on lag1, and then STP will change port to Discarding status if there is loop in your network.
interface lag 1
description 'trunktolan'
port-channel static
no spanning-tree port mode
vlan participation include 8,25
vlan tagging 8,25
exit
- Mark as New
- Bookmark
- Subscribe
- Permalink
Now STP Mode on LAG1 is enable but Admin mode stay in D-Disable and I can't change it to enable
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm afraid there is loop in your network, switch will D-disable the port once receive BPDU Storm in an interface/port, could you please double check again? Last topology picture your provide is only show port 1/0/3 and 2/0/3 connection, how about other port connection? I want to check all up ports connction topoloygy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
but the ports 1/0/3 and 2/0/3 are physically disconnected at the moment, can't I set Admin mode Enable in the LAG when nothing is connected?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I attach the screenshots of the change that I can't apply
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please check if there is error log while enable the LAG port.
Meanwhile, could you please run command as 'show interfaces status err-disabled', it will display the reason for D-Disable state. BPDU storm would also result in such state
- Mark as New
- Bookmark
- Subscribe
- Permalink
what is the correct syntax?
(M4300-12X12F) >show interfaces status err-disabled
% Invalid input detected at '^' marker.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
no result with this command:
(M4300-12X12F) >en
(M4300-12X12F) #show interfaces status err-disabled
(M4300-12X12F) #
I tried to re-enable the LAG in admin mode enable and collect the logs
- Mark as New
- Bookmark
- Subscribe
- Permalink
